Why is my ps5 not turning on
My ps5 will not turn on. I tried different outlets and different power cords and nothing is working
Bu iyi bir soru mu?
Bu iyi bir soru mu?
does it beep
Bu yanıt yardımcı oldu mu?
If it doesn't, it is possible that the power supply is dead and need to be replaced. See guide: PlayStation 5 Power Supply Replacement. But important to know is, if it beeps and if it's showing any light!
I have a similar issue with my console, but it beeps once, the blue light flashes and doesn’t turn on. What do you think is causing this?
Probably the APU… you can try a reflow first and see how that goes. Otherwise you might want to reball it or replace the chip. This is really difficult and requires some serious soldering skills and expensive equipment. Better to replace the motherboard if you don’t have experience with this or go to a local repair shop for the repair!
@dan0 its very unlikely its the apu better suggesting uart instead of going straight for an apu reflow as it could be anything like a short, bad south bridge or wifi ic
Hi Daniel! The comment was meant for Nitter, but you are right! It could be the south bridge or a short, or something else on the motherboard. Sorry for the misunderstanding.
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 71
