iPod not charging well and I know its not the cord
my ipod touch 1st generation will no longer charge. you plug it in and it will start to charge but then it will instead of a lightning bolt it will have a picture of like a cord that it has when it is full 100% when its only at 4%. all i used to have to do was pull out the cord a little bit on one side but now it wont charge at all
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
ryan smith, if pulling "out the cord a little bit on one side" used to work and now it does not, I would definitely take a good look at the dock connector. It sounds like you either have broken, bend or corroded pins. Of course, you do want to make sure that you cable is okay and try a AC adapter to see if it is charging. Should it charge on AC adapter, consider replacing the battery. BTW the dock connector is soldered onto the logic board and does require some experience, a steady hand, and the right tools to replace. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
ryan smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 396
