Ana içeriğe geç
Guides and repair information for dryers produced by Estate.
Why my dryer is not drying the cloth properly
My dryer is not doing the cloth dry properly
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Check for full lint trap.
Check for clogged exhaust, sometimes birds will build a nest in there. You can disconnect exhaust hose from wall and use an electric blower to blow out any debris. Just make sure you have a tight seal so you won't get any back blast.
Try different settings to see if dryer gets hot on different settings, could be a burned out heater coil if it stays cold using the different settings.
Clean dryer sensor if your dryer has one
Make sure you are not filling it too full. Also, put like clothes together, (light weight fabrics together and heavy fabrics together)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Malik Rehan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 41
