Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
952 Soru Tümünü görüntüle
will not turn on . no power at all
I have charged it. Also did the rest thing and still no power. How do I know weather its the battery or the logic board?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
cmw, there are a few ways to determine what is faulty. You can try and charge the iPod on an AC adapter and see if that makes a difference. Sometimes, the battery gets discharged to low and a USB port can not charge it. Check your dock connector and make sure there are no bend, broken or corroded pins. Clean it with some isopropyl alcohol, a toothpick and some compressed air. You can also try and exchange the battery for a new one and using this guide. Be careful with the battery connector on the logic board, it has the tendency of breaking off. After you do this, reevaluate and see what you get, if there is not difference, you will have to get a multimeter and check the dock connector, the fuse F1 and the power management IC. Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
cmw sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 530
