Ana içeriğe geç
Frigidaire tarafından üretilen buzdolapları için onarım bilgileri, servis kılavuzları ve sorun giderme yardımı.
Why is there water on the bottom of the refrigerator?
Water is pools up under the vegetable and fruit bins?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Theres a clog in the condenser drainage line. Causing the water to back up and leak. Clean the line to unclog and clean remaining water. Sometimes if the freezer freezes up, it'll need to defrost. Which would also result in water under the fridge. I'd definitely would check line first.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
It is usually caused by a clogged defrost drain or a leaky door seal that lets in humid air. A blocked drain prevents condensation from draining and evaporating, leading to water pooling inside the fridge. A damaged door seal can also cause excess moisture to condense and collect as water. Other possible causes include a cracked drain pan, a water line leak, or incorrect temperature settings.
Puan 0
Yorum Ekle
Yanıtını ekle
Alfie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 312
