Ana içeriğe geç
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Soru Tümünü görüntüle
Can't boot system even from internal dvd or external
Hi Guy's,
i suspected my sata hdd had failed as the system would no longer boot. I have since replaced the drive with a seagate 1tb. But can't get the imac to boot from internal dvdrw using the original imac disc, and by holding C before startup. I have also tried to connect two different external dvdrw, one usb and one firewire but neither will boot, i even tried my leopard disc. I have also replaced the ram. Any help would be great.
Cheers
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This may not be a hard drive issue. Try removing the hard drive and booting from the original system installation disk from both the internal drive and the Firewire external drive. Do not use the USB drive. Do you get a tone on startup? Any sounds like beeps? Any color on the screen? Try unplugging the machine, press and hold the power button for five seconds then plug it back in and give it a try.
Bu yanıt yardımcı oldu mu?
Puan 3
6 Yorum:
Hi Mayer, yes tried booting from the original disc but just get a white screen, it ejects the disc after a while from the internal drive and nothing happens when the disc in placed into the external firewire drive. It always chimes on startup.
tarafından
Remove the internal hard drive!
tarafından
yep still wont boot and even with a new hdd. trys to read cd then ejects again.
tarafından
do you know whether or not the disc works on any other computers?
tarafından
yer the disc's boot ok from my other mac.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Carl sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 729
