Ana içeriğe geç
10. nesil Apple iPad için onarım kılavuzları, söküm ve sorun giderme bilgileri; 64 veya 256 GB depolama seçenekleriyle Wi-Fi ve hücresel modelleri mevcuttur. Ekim 2022'de piyasaya sürülmüştür. A2696, A2757, A2777 veya A3162 model numaralarıyla tanımlanır.
My iPad won't charge
So my iPad won't charge. When I first bought it (used) it had some charging issues but after some time it worked fine. I sometimes had to turn the Cable because it didn't charge. But now it completely stopped charging. If I connect the charger it does nothing, if i turn it off and connect it, it boots automatically and a message pops up saying "Accessory connected" but it still wont charge. The Port is clean and I've tried many different Cables, including the original one.
About the "Accessory connected" Message, my iPad 7 keeps getting the same message but charges perfectly fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
From your description, it sounds like the charging port is starting to fail internally. The “Accessory connected” message usually points to the iPad detecting the cable but not making a solid power connection. Since you’ve already tried multiple cables and cleaned the port, the next step is checking the charging port itself—it may be loose, worn, or have damaged pins.
In many cases, replacing the charging port assembly fixes this completely. If not, it could be a charging IC issue on the logic board, but port replacement is the most common solution.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
flo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 278
