Why the light doesn't turn off when the doors are closed?
FGHG2344MF3 - The light doesn't turn off when the doors are closed.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
With the door open, manually operate the door switch in the door jamb and check if the light goes out.
If it goes out it may be that the door is not operating the switch correctly when it is closed. Try manually operating the switch a few times to make sure that it does go out every time and make sure that you're not placing more pressure on the switch than the door would, to operate it.
If it stays on, it may be a faulty door switch.
Here's a link that has a video that shows how to replace the door switch.
Search online for 240505801 to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
check bulb if not burnt out
Please check the question. Thank you.
Sounds like door switch issue not turning off when the door switch is push down . This is the part needs to be replace
PART#240505801
here a video how to change the part .
https://www.youtube.com/watch?v=1N4YFWCs...
have fun its super easy
Hello, Thank you for answer but I have FGHG2344MF3.
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 228
