Ana içeriğe geç
22 Eylül 2017'de piyasaya sürülen iPhone 8 için onarım bilgileri ve kılavuzları. Model: A1863, A1905
Why does the touch not work with its original screen?
Hello I have this iPhone 8 with a cracked iPhone 7 screen on it at the moment, the touch works on that screen but when I try to connect the original display to it the touch do not work (also cracked)
However the iPhone 8 screen that the touch doesn’t work on, the touch does work on an iPhone SE 2 though?
Please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Good afternoon(or whenever you read this)!
Often, cracks in a display can affect the digitizer layer of the display, causing malfunction and a loss of touch functionality.
The digitizer basically informs your device where you are touching the screen.
Often this requires replacing the whole display.
Hope this is of assistance,
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
If you have been installing 7 screens on the iphone 8 check that the ground pins on the end of the touch connector are not pushed in, or disconnect the home button and see if touch works. If it does that will be your problem.
Resim
Puan 0
Yorum Ekle
Yanıtını ekle
Morgan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 195
