Ana içeriğe geç
Repair, disassembly, and troubleshooting information for the Steam Deck with LCD display, a handheld gaming console made by Valve, released on February 25, 2022. Identified by model number 1010.
SSD replacement and self-tapping screws
I've got a launch model Steam Deck and I'm considering swapping up from 256GB to 2TB on the internal SSD. I remember the initial Valve-provided video suggests not opening the Deck as that will likely disrupt the cooling airflow due to using self-tapping screws on the original case.
Should I be replacing the front and back panels at the same time if I want to replace the SSD, in order to avoid this potential cooling problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
When you open it up and finish working on it, spin the screws backward until they fall into place to avoid creating new threads. That will be suffienct for your case.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Firehawke R sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 43
