Ana içeriğe geç
A 15.6in laptop with an identified by model number: BoB-Wai9
How to clean the fan and the heatsink?
Hi I have a MateBook D15 AMD Ryzen 5500U and I want to clean the fan, heatsink and replace the Thermoplaste. How do I it without tearing down the whole laptop and possibly breaking it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
You can safely clean your MateBook D15’s fan and heatsink without fully opening it by using short bursts of compressed air through the vents while the laptop is powered off and unplugged. Gently blow air into the exhaust and intake vents, tilting the laptop so dust can fall out, and avoid spinning the fan too fast by holding it still with a small stick. This helps clear surface dust, but to replace the thermal paste or deeply clean the heatsink, you’ll need to remove the bottom cover and disconnect the fan. It is something best done carefully or by a technician if you’re unsure.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Freaky Bob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 249
