Ana içeriğe geç
Nintendo Switch Joy-Con kontrolcüleri için onarım rehberleri ve bilgiler.
Right joycon doesn't connect wirelessly
Hello
my right joycon works only when attached on the switch but does not connect wirelessly when taken off, the switch doesn't even recognize it.
It is not an antenna issue, i've already tried replacing it, its not a switch issue as it works with other joycons, the joycon (that doesn't work) doesn't connect wirelessly to any switch i've tried it.
From reading i suspect it being a problem from the bluetooth chip on the motherboard, any suggestions?
edit: I've tried connecting the right joycon to my phone via bluetooth and it doesn't show up but trying with the left one it does show up
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
In this case it does sound like a issue with the bluetooth chip. So replacing that chip will most likely solve it. Soldering is required for this.
I would just replace the motherboard. You can buy them on Ifixit when it’s in stock. Otherwise you can try AliExpress. They are not that expensive, so it’s worth it in my opinion.
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
took a long time to get the replacement part, but in the end it works now after replacing the motherboard
tarafından Paylaş
Alright! Good to hear that it is fixed anyway now :)!
Have a great day!
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Astronyu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 62
Her zaman: 420
