Ana içeriğe geç
Sony Cyber-shot DSC-W5 5.1 Megapiksel
Can't open battery compartment
I haven't used my Sony dsc-w5 for several years. I am now unable to open the battery comparment. I suspect the battery has leaked and corroded the latch from the inside. How can I open the latch without damaging it?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
charles, you could try and soak the corner with the battery door in a backing powder solution, and/or use a sprayer to try and spray some around the corners. Also, a toothbrush scrubbing might get it loosened. If you soak it, just place that particular corner in a solution, not the whole camera. The only other way is to disassemble the camera, the attached images may help you with that task. Hope this helps, good luck.
Resim
Resim
Resim
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
charles sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 2,149
