Ana içeriğe geç
Televisions made by the Chinese multinational electronics company, TCL.
when I turn it on it has light but doesnt work its not used long time
it has not been used for a long time when i turn it on it only have light below but doesnt work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@eazye73965 sounds like you are saying that your power LED turns on but the TV does not. We will need to know the exact model number for your TV.
Since the power light turns on, you will know that your main board has standby voltage. Next you will need to measure the voltages from the power board to the main board to see which circuit received power and which does not. Remove the back cover and take a good look at the boards and check for any missing, damaged looking component.
Take some well focused pictures and post those with your Question. that way we can see what you see and hopefully point out where to check and what results to expect. For now the prime suspect is the main board with the power board being the next suspect :-)
Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
EAZY E sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 48
