Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
715 Soru Tümünü görüntüle
How critical is Dust inside laptop
In my desktop computers, dust in the fan and heat exchanger areas is critical but easy to remove.
In a mac laptop (I use an iBook, MacBook and now a MacBook Pro) how concerned should I be vs dust stuck in the heat exchanger area and how do I clean it (air can blowing inside?).
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Just watch your heat over the years. It's according to where you live as to how much dust build up you get. Also I've found that households that use a vacuum cleaner a lot are much more subject to dust build up in the machines. The dust stays in the air longer and your machine acts like a filter. Usually a machine is good for four years before you need to get in and clean out the heat sink vents and reapply thermal paste. But I've also seen up to 90% blockage of those vents. So, if it's not getting hot, don't fix it.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
elder norm sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 946
