The DS won't turn on. Green light flashes for a second.
Hello,
Again I have a question about a DS Lite. This time it has the problem that it won't turn on. The green powerlight flashes for a second or two though. When I remove the Wi-Fi module, and then turn it on, the green light stays green, but it still won't power on.
I think it might be the upper LCD screen, since I replaced that. I read in someone elses question that the cable wasn't plugged in all the way. How far should it go in?
I have big fingers, so I can't really put it in farther since I can't get grip on it...
Do you think the LCD is the problem indeed (makes sense ofcourse), or something else? I tried the fuses F1 and F2, both seem to be fine.
Thank you.
Johan
Bu iyi bir soru mu?
1 Yorum
This is unfortunate, have you checked both the top along with the bottom "shells" of the DS? If you do need a new ribbon cable for the top to bottom displace, then there are some people on ebay with them. I can get a link if you cant find one.
Thorhian tarafından
