passenger window won't go up
trying everything to see about getting it up.by holding both buttons down then up on the driver's door control, then doing the same with the passenger door with no luck trying do the same thing.
Bu iyi bir soru mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 198
@andrewjbenner so are you saying that the passenger door window does not go up either by door switch or the master switch on the driver door?
oldturkey03 tarafından
I’ve had this issue. Goes up with the passenger door window switch. But not the master driver switch.
Any thoughts?
Stuart Whetsell tarafından
@stuartwhetsell bad master switch? Have you checked that out yet? Your car the same make and model as for the OP?
@oldturkey03 mine is an 2015 outback. v6.
likely is a master switch. any advice on how to troubleshoot or replace?
@stuartwhetsell the Legacy and the Outback share the FSM for this series. Anyhow, here is the Glass Windows Mirrors chapter form the FSM. Page 16 is the one of interest since it shows how to inspect the switch and the function.
