Ana içeriğe geç
Battery indicators blinking, unit doesn't work
Installed new battery and unit doesn't work. Battery indicator (4 bulbs) flashes
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Assuming that the unit worked prior to installing the new battery, then the battery is likely a dud.
If the battery is brand new, then you should try to get a replacement from the seller. You can also contact Milwaukee directly: https://www.milwaukeetool.com/support/re...
Counterfeit batteries are a major issue unfortunately, and if you purchased the battery online from Amazon, Aliexpress, Temu, etc, there is a high likelihood that the product you bought was a knockoff.
Since these batteries have tightly packaged lithium cells, it is not reccommended to open the battery pack or attempt to repair it.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I used all original milwaukee batteries, the batteries worked in other tools perfectly fine. I wonder if I somehow bind up the gears during the last usage. The blinking lights indicate overheating but I put fully charged battery in it the next day....same result
tarafından
Interesting... Milwaukee tools have a lot of overheat sensors which prolong the life of the tools but if the sensors themselves break, this can cause other issues. Given that Milwaukee has stellar warranty, I'd probably go that route since they have OEM parts and can probably fix this easily.
tarafından
Yorum Ekle
Yanıtını ekle
VoeunK24 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 40
Her zaman: 178
