Ana içeriğe geç
The Whirlpool WRS588FIHZ is a side-by-side stainless steel refrigerator with a total capacity of 21.7 cu. ft., featuring frameless glass shelves, LED lighting, adjustable gallon door bins, and a factory-installed ice maker. It is equipped with electronic temperature controls, temperature alarm, automatic defrost, and is ADA compliant.
Water leaking from top and bottom of freezer door. (WRS588FIHZ00)
Why is water leaking from top and bottom of freezer door during ice tray filling. The entire ice filling system and both water source solenoids have been replaced
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @warrenreading
Check if the water is not stopping straightaway when the ice tray is full and is overflowing the ice tray during the fill function of the ice maker
I realize that you've replaced the ice filling system (assume you meant the ice maker) so perhaps there's wiring problem or a control board issue.
Here's the tech sheet for the refrigerator.
Enter the service diagnostic mode as described in the sheet and perform Test #45 - Ice maker water fill test and check if tests OK i.e. Off, On and Paused and that the water is turned off when Off or Paused is selected.
If it doesn't, then check if the ice maker switch wiring back to the board is OK. (see wiring diagram I think they go to the P7 plug pins 3&4 on the control board but you may want to double check)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Warren Reading sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 68
