Ana içeriğe geç
Laptop's key not working
My laptop's space-bar is not working how do I fix that ? Without replacing the whole keyboard, cause the other key's are working fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The way HP builds them... No :-(. You need the whole palmrest.
HP SM: https://h10032.www1.hp.com/ctg/Manual/c0...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Gently pry off the spacebar keycap (use a thin plastic tool). Clean underneath with compressed air to remove dust or debris. Check the metal stabilizer bar and rubber dome — if misaligned, reposition carefully and snap the key back on.
If cleaning doesn’t help, you can replace just the spacebar key kit (keycap + hinge + rubber) instead of the entire keyboard.
Puan 0
Yorum Ekle
Well I will suggest you update the keyboard driver sometime outdated driver can also be the reason for this issue so make sure your driver is updated to it's latest version.
Puan 0
Yorum Ekle
There’s no easy way to fix broken keys. If it’s broken, you’ll need a new top cover part. HP keys can’t removed and reattached. We just swap out the top cover with keyboard, which means all the other parts, including the motherboard and the LCD assembly has to be transferred over to the new top cover with keyboard.
If there was an easy way to fix just one key, HP would have supplied to means and parts to save cost. They don’t, so we replace the entire top cover instead.
Puan 0
1 Yorum:
TECHINCALLY lost key caps are doable with spares but not entire boards.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Person sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 222
