water damage, won't turn on
Hi somebody,
My canon was dunked in water and after drying it out the camera makes no function...
how many fuses are and where they are?
Thaks,
Vidma
Bu iyi bir soru mu?
Hi somebody,
Thaks,
Vidma
Bu iyi bir soru mu?
vidma, the image will show you where the power fuse is located. Just remember that with water damage, a good cleaning with isopropyl alcohol is a must. Otherwise, you run the risk of corrosion failure later on. Here are more reason why your camera may not get any power:
"If electrical conduction is not found:
• FUSE is blown; replace it with a new one.
If the FUSE is not faulty:
• MAIN PCB Assembly excluding the FUSE is faulty
• OPERATION FPC Assembly is faulty
• TOP COVER UNIT is faulty
• BATTERY COVER is damaged.
• DETECT SWITCH(MAIN PCB assembly) is faulty"
Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Hi oldturkey03 I replaced the main then also cam is not getting on.where can I get all cam spares.plz help
canon sd 1100 got dunked in juice , cleaned with ip also replace fuse 1001 then also not getting 8n plz help.
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 2,085
6 Yorum
Have you disassembled and cleaned it yet?
oldturkey03 tarafından
Hi oldturkey03, Thanks for the very fast and full-scale response!
I"ll try a bit later.
vidma
vidma tarafından
the FUSE was not faulty,
I cleaned with alcohol, shorted the SWITCH on battery door, but still nothing.
Think stray current made more serious damages :(
vidma tarafından
vidma, try to clean the logic board with with isopropyl camera. There are a few more fuses on the logic board. Check all those for continuity.
Thanks oldturkey03, but how to find them, could you send me service manual with repair instruction and diagrams?
vidma tarafından
1 tane daha yorum göster
