Water mix with oil how to fix it
My car is not starting and is switching on and other parts work accept angen cracks. I need help.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Strange, same question two separate OP's in just a few hours :-) Anyhow, just in case, here it goes
@lonelymabale the most common issues for that are:
You did not tell us what you have already checked or if anything happened to your MB just prior to this. At minimum I would suggest a compression test as well as a Cylinder Leak-Down Test which will be the most diagnostic test.
For any further help, we will need to know the exact engine size/model of your Mercedes Benz
Should be one of these:
M111 (2000-2002): Supercharged 2.0L or 2.3L
M271 (2002-2007): 1.8L Supercharged inline-four (C180K, C200K, C230K)
M112 (V6): used in C240 and C320
M272 (V6):
AMG (C55): Uses a 5.4L naturally aspirated V8.
Diesel Engines:
OM611/OM646: 4-cylinder engines.
OM612/OM647: 5-cylinder diesel engines.
C30 CDI AMG: High-performance 3.0L
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 28
Her zaman: 152
