Ana içeriğe geç
Apple'ın Mayıs 2019'da piyasaya sürdüğü yedinci nesil iPod Touch. Bu model, 256 GB'a kadar depolama alanı ve A10 işlemci ile gelir. Model numarası A2178.
Can't remove the front display!
It seems impossible to remove the front display! I used the iOpener repeatedly, a heat gun, all to no avail. I bought a new display and all the tools to replace it, but I can't get started. The adhesive just doesn't want to budge! Help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
OK I got it open now. It took 3-4 days of working t it. Hint to others: The display started to separate slightly on the side, at about 3/4 " above the bottom. I was able to get a razor blade between the display and the frame and slid it down to the bottom, then pulling it across the borttom cutting the adhesive. Now it is on to the rest of the work! DBS
tarafından
@davidswans58182 Congratulations!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If the front display won't come off, don't force it. Double-check that all screws and ribbon cable connectors have been removed or disconnected. The display may still be held by adhesive clips—apply gentle heat around the edges and use a plastic opening tool to carefully separate it. Forcing it can crack the screen or damage the frame.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
David Swanson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 182
