in my iPhone 4 the screen is very dark
my phone is wet and faded. I turn on the phone when the brightness is gone and I can see only sunlight against a solution .. thank you very much
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Sounds like the backlight has gone! The backlight to your iPhone is probably the most energy-intensive component to your iPhone. It requires alot of power and will have a minimum operating voltage of only a few volts. I see that you have two options;
1) Place your iphone with the back and preferably the logic board (as much as you can really) removed and place it into a dry bag, placing it in a bag of dehydrated rice and then in a dry, warm room like the drying room or pantry overnight should remove any ecxess water or water vapour.
This would be a lucky fix but, only cost you 99p.
Your second option; buy a new display assembly and replace the LCD with its back light completely. This has a much higher chance of working and although very fiddly, it will most definitely (99% sure) work.
Just make sure you order the right one! (either the 4G or 4S) as the two are not compatible unless you want to use an angle grinder and force-fit it, which I as a novice have done and succeeded, but I wouldn't recommend it!
Hope this helps!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,876
