Ana içeriğe geç
2016 yılının başlarında piyasaya sürülen, 2015 model Retina MacBook'un güncellenmiş versiyonu için onarım bilgileri ve kılavuzları. Model A1534 / EMC 2991
Everything replaced. Keyboard doesn't work
You know, I've been so dedicated to fix this %#*@ thing. New battery, new logic board, new bottom case with new keyboard (got two because first one was bad). new trackpad, new cables and yet...... the keyboard STILL doesnt work. At this point, with money sunk into this....I guess its just ready to retire. Not sure if anyone has had this experience, but its been pretty frustrating. Everything else works fine otherwise.
Mouse works fine... power button works fine. Just been the keyboard. I've gone through every variable I could think of.. at this point I have no clue what else there.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It is likely that the very fragile cable from the keyboard / Track pad is either not fully connected or latched down or it has been damaged which is very easy to do on these models. Be careful it did not overheat from something not fully connected or whatever as then it is truly game over as there is no cooling fans on these models and the CPU will overheat & eventually short out. I have one here that suffered the same plight.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Andrew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 94
