Loud clicking starting cycle and also FL error. What is wrong?
What is wrong with my Kenmore Elite HE3 washer. There is loud clicking at start of machine at times and today, would not start at all--had FL error.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
PFS, I checked through the service manual but can not find any FL error (possible that it is FdL?). I would start off by trying to reset the washer. check this copy from a different answer "If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement. You can also try to reset the CCU by unplugging the washer for AT LEAST 30 minutes." you can download a service manual from here" Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 498
