DIY guides for many household repairs, ranging from furniture to plumbing solutions.
3050 Soru Tümünü görüntüle
dryer maytag DE 303 door button
arced the shut off wires on door, now it does not shut off when you open the door or control knob, also no heat.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
When you say "arced", what happened to it?
tarafından
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
jim, If the motor doesn't stop when the door is opened, it is most likely the due to a defective door switch. The door switch may also control a relay, which in turn controls the motor or fan as well as the heating element. I would start by replacing the door switch first. It is available at places like this. Part number 9 in the image is the switch. After you replace the switch, reevaluate and see what works, and what doesn't. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
jim sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 266
