Ana içeriğe geç
Nintendo GameCube Kontrolcüsü DOL-003. Kasım 2001'de piyasaya sürülmüştür; Nintendo GameCube ve Nintendo Wii ile uyumludur, ayrıca daha sınırlı bir kapsamda Nintendo Wii U ve Nintendo Switch ile çalışmaktadır. Bu cihazın onarımı oldukça basittir ve yalnızca yaygın kullanılan araçlar gerektirir.
Why can't I close my gamecube Controller shell
I decided to buy a gamecube Controller replacement shell from extremerate. But when i tried to install it . It wouldn't close! Btw I have type 3 motherboard
Resim
pls help me 🙏
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
Make sure the triggers are good aligned, otherwise it won’t close easily. Also check the rumble motor. If it isn’t inserted correctly (wrong way) it won’t close easily either.
Hopefully that is it. Otherwise try again with the original shell, if that one works right away, it’s related to the case…
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Unfortunately my old shell is bent so I cannot use it ever again. And it is not the problem with the trigger position I always align them perfectly. And my rumble motor Is aligned in the right direction so I have no idea what might be the problem.
tarafından
@krzysztofh47108 it might be caused by a casing with poor quality. In theory extremerate's products are usually pretty good but it might still happen. I've came across aftermarket casings for the Xbox 360 controller and they won't close as well. You might need to compare it to your original casing and shave off extra stuff.
Also since you mentioned that your old shell is bent then it might be a bent motherboard.
tarafından
My motherboard is fine the problem with the old bent shell was that i used the hairdryer ( because I was cleaning it) and it melted and deformed in some places so it is unusable and about cutting the shell. I would want to try it but I am not sure what piece of the new shell should be cut. Any tips or ideas about that?
tarafından
I would get a donor/broken controller and get the shell from there. It will save you a lot of trouble. You need to compare the shells with each other whenever you want to use a 3rd party one. Where did you bought it? Thank you!
tarafından
Yorum Ekle
Yanıtını ekle
Krzysztof Horodeński sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 117
