The Kenmore Elite HE3 is a washing machine by Kenmore.
620 Soru Tümünü görüntüle
My washer is half full of water.
I cannot get the drain/spin cycle to work.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
greta, here is my answer to a similar question "if it won't drain check this items according to the Service Manual from here
1. Check Wire Harness connections.
2. Check Drain pump.
3. Check Drain pump motor.
4. Check that the Drain hose and Drain Pump Filter are clear of foreign objects.
5. Check the CCU.
Page 52 of the same manual tells you how to run a diagnostics. See what error code you get on your washer. Of course when you get to the drain pump (available here) check the inlet and outlet for missing socks ;-) etc. sometimes you will find the weirdest things in there." Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
greta sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 11
Her zaman: 1,601
