Ana içeriğe geç
Complete disassembly and installation guides for most iPods, including iPod Original, Mini, Shuffle, Nano, and Touch.
7335 Soru Tümünü görüntüle
Small steel ball inside
When I opened my ipod g4 I found a small steel ball inside.
Where dose this go?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
A picture would be helpful...it would be obvious if it were
a solder ball if we could see it.
Why did you open your ipod? Was there a problem to begin with?
tarafından
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check to see if it is a steel ball or a drop of solder. I do not think a steel ball belongs in the ipod.
The drop of solder would not have been left in the unit. Inspection should have caught any foreign material, steel ball or drop of solder.
I suspect that a short in the charging system, the only place enough current exists in the unit to melt solder, may have taken out a component. The result may have been a current draw sufficient to destroy enough circuit material to leave the residue you speak of. I think such destruction will be obvious and you will find the culprit.
Good luck and as my son says, "keep smiling!"
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
James Hartman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 202
