big red x
I have an iPod classic 80gb, when i turn it on their is big red x and it will do nothing else
Bu iyi bir soru mu?
Bu iyi bir soru mu?
carrie, reason for the big red X is usually a bad hard drive. Try to place the iPod in diagnostic mode, follow the instructions for that from here. you can also try to place the i{Pod in disk mode and see if you can access the harddrive and try to format it. I use a Zif-to-USB adapter to check the drives, you can get those adapters for cheap on places like ebay. Ultimately, I believe that you will need a new hard drive. The guide for the repair is here.The hard drive is available at many places and not a terrible job to change it. There are those that recommend to "slap", literally hitting the iPod hard on the back. Sometimes, it loosens a frozen drive. I prefer to change it and to fix it for sure. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 809
