No backlight after screen replacement z3 xperia compact
I changed the screen because it cracked. When I first tried the screen it was fine and it worked. Then after a while the backlight didn't work. The screen works and I can barely see things on the screen, but backlight is not working.
I read there is a fuse that helps fix this issue but I don't know if this will help. Here it is: http://www.mobilerdx.com/2015/03/sony-xp...
It's the first time the phone is opened and I never thouched the fuse because it's underneath a metallic plate, which I didn't even touch or moved. So why would I have to do something with the fuse if I never did anything to it and the screen was working when I tested it?? It just stopped working afterwards for some unknown reason.
The phone is on, because there is the blinking light. So, do you have some suggestions??? Should I actually try to add a jumper on the fuse??
Thanks.
EDIT: I remember that when I was about to close the phone I put the screen upside down, and it was when the screen backlight stopped working. Is this some reason why the fuse could have been damaged???
Thanks
Bu iyi bir soru mu?
1 Yorum
i have the same problem. After I replace the screen of my phone. The brightness become so dim. I tested na light sensor but it is working.
Denmark tarafından
