1 Diyagram
Popüler Forum Soruları
Bir soru sorHiç soru yok. İlk soru soran siz olun!
Belgeler
Model
138.37097
Background
The Craftsman Corded Electric Mower 138.37097 is a corded electric lawnmower that uses a 120-volt power supply and operates on a frequency of 60 Hertz. The mower runs on an alternating current and uses 13 Amps of power. It boasts a no-load speed of 3,600 RPM, allowing it to cut grass efficiently across its 21-inch cutting path. The height of the mower can be adjusted from 1-3/4 inches to 3-3/4 inches, making it adaptable to various grass lengths. It weighs 53 lbs, making it a relatively lightweight option for its size and power.
The mower comes with several features designed to enhance usability and performance. It is equipped with a cord retainer to secure the extension cord during operation. The device also includes a grass catcher, which collects clippings to prevent them from scattering across the lawn. The mower also features a height adjustment lever for cutting height alterations and a motor/blade control assembly that engages and disengages the motor and blade. A mulching plug is included, which cuts and recuts the grass for finer clippings. Additionally, the mower has a side discharge deflector for when the grass is too high to mulch or side discharging is the preferred method.
Technical Specifications
- Model Number: 138.37097
- Product Type: Corded Electric Mower
- Input: 120 V, 60 Hz, AC only, 13 Amps
- No-load Speed: 3,600±10% r/min. (RPM)
- Cutting Path: 21 in.
- Height Adjustments: 1-3/4 in. to 3-3/4 in.
- Weight: 53 lbs (24 kg)
