19 Diyagram
Popüler Forum Soruları
Bir soru sorHiç soru yok. İlk soru soran siz olun!
Model
HRS216K5 PKAA
Background and Identification
The Honda model HRS216K5 PKAA is a gasoline-powered walk-behind push lawn mower that discharges cut grass to the side. The lawn mower is powered by a Honda GCV160 engine. The push lawnmower features Honda’s Auto Choke System that does not require any engine choke for easy starting. The lawn mower is designed to be easy to maneuver and can be adjusted to six different cutting heights between one inch and four inches.
The Honda model HRS216K5 PKAA lawn mower includes a 21-inch heavy-duty 16 gauge steel deck and a two-in-one mulch/side discharge. The mower includes a manual fuel shut-off valve, and fuel stabilizers should be used to maintain the engine to increase the lifespan of the mower. The Honda GCV160 engine is an air-cooled four-stroke overhead-camshaft engine that displaces 9.8 cubic inches or 160 cubic centimeters (160 cc). It produces 4.4 horsepower at 3600 revolutions per minute and 6.9 foot-pounds of torque at 2500 revolutions per minute. The engine’s fuel tank can hold up to 0.98 quarts (0.93 liters) of gasoline and up to 0.58 quarts (o.55 liters) of oil. Honda recommends using unleaded 86 octane or higher fuel.
The mower features quick-fold handles for convenient storage and transport and an easy twist knob release handle for folding. The HRS216K5 PKAA model’s eight-inch front wheels and ball bearing rear wheels are designed to move smoother over varied terrain, though the lawn mower is only recommended for use over flat and sloped terrain.
Technical Specifications
Dimensions:
- Assembled Depth (in.): 44 in
- Assembled Height (in.): 19 in
- Assembled Width (in.): 23 in
- Blade Length (in.): 21
- Cutting Width; 21 inches
- Front Wheel Size (in.): 8
- Mower Deck Width: 21
- Rear Wheel Size (in.): 8
Details:
- Assembly Required: Yes
- CA (CARB) Compliant: Not CARB Compliant
- Cutting Height Options: 6-position
- Cutting Options: Side-Discharge
- Deck Material: 16 Gauge Steel
- Deck Type: Stamped
- Engine Displacement (cc): 160
- Engine Make: Honda
- Engine Torque (ft.-lb.): 6.9
- Features: No Additional Features
- Fuel Tank Capacity (gallons): .25
- Included: No additional items or accessories included
- Lawn Mower Type: Push Mower
- Maximum Cutting Height (in.): 4
- Minimum Cutting Height (in.): 1
- Mower Size Type: Standard
- Number of Blades: 1
- Number of Handlebar Positions: 2
- Oil Capacity (oz.): 12
- Power Type: Gas
- Product Weight (lb.): 66
- Rear Wheel Height: High Wheel
- Recommended Oil Type: 10W30
- Recommended Terrain: Flat, Sloped
- Size of Yard: 1/4 - 1/2 Acre
- Start Type: Pull Cord
- Walk-Behind Mower Type: Manual Push
