Ana içeriğe geç
Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: adım 1, 2 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: adım 1, 2 resimden 2.
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 2, 1 resimden 1.
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: adım 3, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: adım 3, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: adım 3, 3 resimden 3.
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 4, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 4, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 4, 3 resimden 3.
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
  5. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Remove the yellow tape covering the ribbon cable in the bottom left of the motherboard as shown.
    • Carefully remove the ribbon cable out from the connector.
  6. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 6, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 6, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 6, 3 resimden 3.
    • Fold up the grey cover to release the ribbon cable in the bottom right of the board as shown.
    • Carefully pull out the ribbon cable from the port by the blue tape.
  7. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 7, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 7, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 7, 3 resimden 3.
    • Fold up the white cover to release the ribbon cable in the top left of the board as shown.
  8. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 8, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 8, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 8, 3 resimden 3.
    • Fold up the grey cover to release the cable on the top right of the board as shown
    • Carefully pull out the cable from the port.
  9. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 9, 2 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the cable with tweezers as shown along the top of the board.
  10. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 10, 2 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 10, 2 resimden 2.
    • Carefully pull off both brass connectors from the top left of the board with tweezers as shown.
  11. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 11, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 11, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the six screws from the board as shown. There are two types of screws here, so be careful to keep them separate for reassembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
7 Yorum
thanks for the write up! do you know where the bluetooth is on the motherboard? I presume step 10 are the connections to the wifi antennae?
leerandmcnally - Yanıt
This Chromebook likely uses a dual chip which can be seen in step 10. I’m guessing the chip is a 802.11AC 2x2 MIMO WLAN + Bluetooth 4.0 from looking at the specs.
Blake Klein -
wich is the firmware write protect screw on the motherboard to cheng the os to win10 ??
loudikov - Yanıt
This is an ARM MT8173 machine, no Windows 10 for this hardware… Win10 for ARM is still on ARM based Surface, and gives poor experience.
Roberto Giuffrè -
Bonjour,
J ai un chromebook CB5-312T quelle carte mère je dois acheter et où mon chromebook ne s allume plus.
Merci
Celine Gaidot - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 2,175
