Ana içeriğe geç
Acer Iconia One 7 Battery Replacement
Neye ihtiyacın var
  1. Acer Iconia One 7 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
  2. Acer Iconia One 7 Battery Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Battery Replacement: adım 3, 1 resimden 1.
    • Turn the tablet over so the battery is facing up.
  4. Acer Iconia One 7 Battery Replacement: adım 4, 2 resimden 1. Acer Iconia One 7 Battery Replacement: adım 4, 2 resimden 2.
    • Carefully pull back the black tape covering the battery lead connector.
    • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
  5. Acer Iconia One 7 Battery Replacement: adım 5, 3 resimden 1. Acer Iconia One 7 Battery Replacement: adım 5, 3 resimden 2. Acer Iconia One 7 Battery Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Using a plastic card or opening pick, separate the battery from the rest of the device.
    • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Ahmad Kayali
458 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 8-5, Eyestone Fall 2015 USF Tampa, Team 8-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G5
3 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Yanıt
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Yanıt
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Yanıt
Where I can order the new battery part?
melanieloa3 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 18,244
