Ana içeriğe geç
Kindle 2 Battery Replacement
Neye ihtiyacın var
  1. Kindle 2 Battery Replacement, Battery: adım 1, 3 resimden 1. Kindle 2 Battery Replacement, Battery: adım 1, 3 resimden 2. Kindle 2 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
  2. Kindle 2 Battery Replacement: adım 2, 2 resimden 1. Kindle 2 Battery Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
  3. Kindle 2 Battery Replacement: adım 3, 2 resimden 1. Kindle 2 Battery Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Kindle 2 Battery Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
  5. Kindle 2 Battery Replacement: adım 5, 2 resimden 1. Kindle 2 Battery Replacement: adım 5, 2 resimden 2.
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
Sonuç
39 farklı kişi bu kılavuzu tamamladı.
Dayna Scott
955 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-32, Amido Spring 2013 Cal Poly, Team 12-32, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G32
4 Üyeler
14 adet Kılavuz yazıldı
9 Yorum
I followed this guide, without changes, and was able to successfully swap a battery on a Kindle DX. The DX is essentially a Kindle 2 with a larger screen.
Eric - Yanıt
Thanks, easy and went well!
Maybe you need a thinner spudger, TH?
Laz - Yanıt
Easy! Worked well with the tools described. Kudos for making this available, it gave my old Kindle a new breath of life!
stevenwaegenaer - Yanıt
Easiest replacement I've done. Thanks!
shockwav - Yanıt
An ebay-acquired battery fit perfectly, but failed to reboot the kindle or accept a charge.
the battery looks idential to the Kindale battery to an old analog voltmeter.
I conformed that the kindle terminals were receiving battery voltage.
The replacement guide was just fine, Back to the original battery, which is well past its best-by date!
Charles Kennedy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 58
Son 30 gün: 280
Her zaman: 34,861
