Giriş
Use this guide to replace the display assembly of your MacBook Pro 13" Touch Bar Late 2016.
Before starting this procedure, you may want to check with Apple to see if you qualify for a free repair. If your display’s backlight has stopped working, or the display shows vertical bright areas along the entire bottom of the screen (a.k.a. “stage lights”), your MacBook Pro may be eligible for Apple’s display backlight service program.
For your safety, drain your MacBook Pro's battery below 25% charge before starting repairs.
Neye ihtiyacın var
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.2 mm screws
Four 3.4 mm screws
Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
Lift the suction handle to create a slight gap between the lower case and the chassis.
Insert one corner of an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the nearest corner and halfway up the side of the case.
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Use a spudger to gently lift the battery power connector, disconnecting the battery.
Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Remove the four 1.9 mm T3 Torx screws securing the plastic covers on top of the display hinges.
Remove both plastic hinge covers.
Remove the four 3.9 mm T3 Torx screws securing the two display cable cover springs.
Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the cover spring.
Use a pair of tweezers to pull the cover spring of the display cable out of its recess.
Repeat this step with the right cover spring of the display cable assembly.
Fully open your MacBook and gently place it keyboard-side-down on a table so the screen hangs over the edge.
Support the screen with one hand and use your free hand to remove the six T8 Torx screws securing the hinges.
Firmly secure the main body of your MacBook with one hand.
With your free hand, push the left side of the screen up and towards the bottom of your laptop to free the left hinge.
Free the right hinge and remove the screen.
Make sure the screen hinges are fully open and guide them into their recesses in the frame.
Partially tighten the six hinge screws.
Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
Fully tighten the hinge screws.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
77 farklı kişi bu kılavuzu tamamladı.
29 Yorum
Hello Lucas Zhu,
the interior build of the A1708 model is a bit different to this one. Especially the connection of the battery. You can check our guides for the A1708 model for the disconnection procedure. The removal of the display in general, is more or less the same with a few differences (e.g. two instead of 3 coax cables). Although the A1708 is a different model you might be able to remove the display following this guide.
THANK YOU THANK YOU THANK YOU!! You made my life so much easier. This guide was thorough and definitely made things a lot easier to understand.
Thanks for the guide! I’ve completed mine around 1 1/2 hours while being really careful not to short-circuit any components. Other video that I used for reference: https://youtu.be/153tVLIZVm8 and https://youtu.be/bEDhEWLrkUs
