Videoya Genel Bakış
我们从我们的合作者Creative Electron那里用x光窥探了整个机身。
如果你喜欢S8,我们有好的消息 - 三星同意你的看法。 除了新的(和更好的)指纹传感器位置外,设计看起来几乎完全没有变化。
我们的S9的左边是他的祖先s8(从我们的2017拆解重新组装)和右边的S9 +兄弟姐妹(上个周末我们的拆解现在仍然感觉疼痛的s9+)。
支持三星保持耳机插孔和可扩展存储,同时保持IP68防护。
Bu adımda kullanılan alet:iFixit Adhesive Remover$19.99
与一些旗舰相比,S9拥有两倍的光圈系数f-stop和一半的传感器。
未显示:三星高度吹捧的2 Gbit LPDDR4 DRAM,位于图像传感器正下方。
如图所示:其他一些神秘筹码。
RD938
ST Micro 743 2NWT(可能是用于光学图像稳定的2轴陀螺仪)
GigaDevice GD25LQ32 32 Mb串行闪存
让我们看看为所有那些奇特硬件提供动力的芯片:
三星K3UH5H5-OMMAGCJ 32 Gb(4 GB)LPDDR4X DRAM,通过高通骁龙 845
东芝THGAF8G9T43BAIR 64 GB UFS(NAND闪存+控制器)
安华高AFEM-9096
高通 Aqstic WCD9341音频编解码器
Maxim MAX77705F PMIC
Skyworks 13716
IDT P9320S无线电力接收器可能类似于P9320
另面是集成电路的聚集:
村田KM7N07016 Wi-Fi /蓝牙模块
恩智浦PN80T NFC控制器
高通PM845(可能是PMIC)
高通 SDR846 101(可能是RF收发器)
很难弄清楚,但我们认为这很可能与我们在S9 +中发现的SkyworksSKY78160-11前端模块相同,
高通PM8005 PMIC
Hard to make out but I think you’re right. We updated the text. Thanks for the tip!
- 许多组件都是模块化的,可以独立更换。
- 电池更换在技术上是可行的,但找到它是一个不必要的挑战。
- 正面和背面的胶合玻璃意味着更大的破损风险,并使修理难以开始。
- 屏幕维修需要大量的拆卸,同时与坚韧的粘合剂作斗争。
Son Düşünceler
Onarılabilirlik Puanı
(10 en kolay onarılabileni)
Bu çevirmenlere özel teşekkürler:
77%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
16 Yorum
Hello:
So, no radio on this model either?
Thanx for another great video and teardown explanation : )
Is there any physical difference between the Qualcomm Single & Dual-SIM versions (ditto for the Exynos versions)?
Was just curious if the only difference is the software & possibly the SIM Tray,to where you could convert,say,a US Single SIM version to a Dual-SIM version found in the other markets.
Physically my s9 in okay. Except the back glass in broken most likely ran over by car. It boots up just barely. It was working fine until I tried “Okay Google.” As with most glitches I restarted the phone and that's when I realized something was wrong after I found it in the road at work. Popped off the Otter box. Saw the back glass all cracked up. Side to side it appears fine, not crushed. But obviously something from failing off the muffler of a Ford explorer and then sitting in the road internally something is damaged. It will charge, I can reach the Boot menu via the Power+volume down button. Any Ideas on where to go to get repaired? Or….Go to E bay and buy something else since Verizon did not here my request for coverage to be added to my phone on 3 separate occasions and there crappy Insurer denied my claim. Thank you greatly for any consideration to a reply. T. Mills treeoflife23@hotmail.com or westhitter@gmail.com
Anyone knows what is the temparature and humidity sensor in this model?
Do you guys know what the part in the Sim card slot is that ejects the Sim card?
After replacing my screen along with a complete teardown the person I'm talking to hears an echo. What did I do wrong and what part do I need to replace?
Hello i cant deal with its network huge network problem i have been faced since i had bought
Thoughts on repairability with a non working SD card slot? Card that works fine in other devices and used to work fine in this phone (for nearly two years) started randomly dismounting w/ corrupted filesystem when accidentally exposed to, uh, a significant quantity of water with card slot fully closed. I was hoping the card slot unit was on a separate board like the headphone socket but it looks like it's part of the motherboard from here and I'm not liking my chances of desoldering it without a hot air station. I'm guessing it's toast... especially as the screen is shattered too and I can get a whole replacement for ~95 on Amazon vs a new display+digitizer for ~120.
