规格上与S5相比,S6确实可圈可点。下面罗列出来其规格:
5.1寸 Super AMOLED 电容触控屏(1440 x 2560 像素,~577 ppi,16M色彩)
搭载Exynos 7 Octa 7420 处理器与协Mali-T760 GPU,以及3GB运行内存。
1600万像素后置摄像头,具有HDR,LED补光及双视频录制功能。
内建无线充电模块。
32,64及128GB存储可选。
正反面均采用第四代康宁大猩猩玻璃。
更大的电源,更高的像素。但仍感觉有所欠缺。我们还没有开始动手,所以开始拆解吧!
Bu çevirmenlere özel teşekkürler:
94%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
24 Yorum
So once the rear glass is removed once the screws are removed the chassis is removed? As I want to replace my chassis on my s6 at some point and don't want to remove anything I don't need to.
Any help is appriated.
We have a full set of step-by-step replacement guides for the components in this phone!
My wife dunked hers in the Pool right after my Daughter's Wedding so we need to get the pictures off.
I tried drying it out for a week before even attempting to turn it on. However it is dead!
Any suggestions?
dissemble it first and replace the dead battery. Usually that's the first component that fails upon touching water. Once dissambled, replaced the dead battery and try again. You will be able to check the rest of component with a minimum investment. Cheers.
kavenzc -
My son put my s6 in the bath. The motherboard is blown. My data is fine to retrieve. Is there a way I can retrieve my data and how much would it cost? and also without replacing the motherboard? I just want my photos and videos. I'm not worried if my phone does not fixed afterwards.
