Giriş
READ ME: This guide has been archived by the author due to the age of this guide, and the fact this 360 is no longer around. I will not be updating this guide further. I have moved on from this guide but I feel like this could still help someone so I am keeping it around.
Game stuck in your Xbox 360? Here's a way that may work to remove it, in lieu of voiding the warranty (if the console is still under warranty).
Aletler
Parçalar
Hiçbir parçaya gerek yok.
  1. Remove the faceplate from the system. Grab a part of the faceplate, and it should come off. Remove the faceplate from the system. Grab a part of the faceplate, and it should come off. Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
    • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
  4. Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console. If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection. If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
    • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
    • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
Sonuç
17 başka kişi bu kılavuzu tamamladı.
Nick
44.803 İtibar
37 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
280 Üyeler
783 adet Kılavuz yazıldı
2 Yorum
will this work for elite 250 gug
duangphetv - Yanıt
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 14
Son 30 Gün: 88
Her zaman: 29,426
