Giriş
电池耗电太快?一天不得不充电超过一次?本指南将展示如何为您的S7更换新的电池。
本指南包括移除玻璃后盖,你需要重新使用粘合剂将后盖装在手机上。
请注意,视频中建议你取下SIM卡, 这个步骤并非必要,如果取下来了也没有什么负面影响。
在拆解您的手机前,断开电源,将电量使用到25%以下。 充电的锂电池意外被刺穿可能导致意外着火或者爆炸。
如果你的电池鼓包,请勿加热你的手机。 如果有必要的话请使用装有异丙醇酒精(90+%) 的滴灌或注射器在后方滴入,来软化粘合剂。 鼓包的电池可能十分危险,请保护好眼睛,确保安全,如果你不知道该如何处理时,请交给有经验的人来处理。
Neye ihtiyacın var
Videoya Genel Bakış
在电池的每个角下涂抹一些高浓度(> 90%)的异丙醇,并使其渗透几分钟,以帮助弱化粘合剂。
或者,准备一个 iOpener 并直接放置于电池上方来软化胶粘剂。
或者,在电池的每个角下涂一些异丙醇,让它渗透几分钟,以帮助减弱胶粘剂。
要重新组装您的设备,在后壳贴合粘合剂,请按照本指南的相反顺序进行操作。完成此指南之后, 可以访问校准新安装的电池一文。
254 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
57 Yorum
After this is it still waterproof?
In theory, if you applied the replacement adhesive 100% correctly, it will retain its water resistant properties. However, I would never deliberately expose any device to water, as you can never be completely sure that all the seals are perfectly intact.
That is actually covered in the video. Did you actually watch it? If water resistant is important to you then what you would do is purchase new gasket material so that after you have opened up the phone and removed all the existing gasket you would apply the new gasket and then finish up and re-seal your phone. As to how water resistant it is after re-sealing the phone all depends on how careful you are and how exact your work is.
Sooooooooo why exactly did Samsung make it impossible to open the phone?
Because screws are unsightly :P… and repairing your old phone makes you not want to buy a new phone.
