它看起来可能像一台滚筒洗衣机,但是它似乎无所不能,除了洗衣服。看看我们正在拆解的型号(中国版LIO-AL00)的配置:
分辨率为2400 x 1176的6.53英寸OLED显示屏(〜409.29 ppi)
华为麒麟990处理器:8核中央处理器,16核Mali-G76图形处理器以及神经元处理器
后置四摄——分别为 4000万像素 ƒ/ 1.8、4000万像素 ƒ/ 1.6、800万 ƒ/ 2.4(3倍光学变焦)和3D深度感应摄像头
3200 万像素 ƒ/ 2.0前置摄像头,以及3D深度感应摄像头
IP68 防水防尘,USB-C端口(无耳机插孔)
面部识别,手势识别和屏下指纹传感器
这四颗镜头是华为营销的重中之重——它们也不虚此名。这庞大的规模有:
4000万像素 ƒ/ 1.8 电影摄像头,使用1/1.54英寸,经典RGGB阵列的IMX608传感器,3:2输出比例。
4000万像素 ƒ/ 1.6 超感光摄像头,使用1/1.7英寸,华为独有RYYB阵列带光学防抖的IMX600传感器,4:3输出比例。
800万像素 ƒ/ 2.4 长焦摄像头,使用带光学防抖的OV08A10传感器,支持3倍光学变焦,5倍混合变焦,最大30倍数字变焦。
3D深度感应摄像头,通过IMX316传感器实现实时深度视频效果
主板上剩下的似乎是点阵投影仪模块,该模块为3D相机提供信息来源。
- 几乎所有组件都为模块化,可以单独更换。
- 所有螺丝都是十字形。
- 拆除后盖,塑料框核一些排线后,可以快速更换电池。
- 少数组件更换较困难。
- 可以不拆除电池就更换屏幕,但是在线缆的阻挡下很困难。
- 粘在一起的前后玻璃更容易摔碎,并让维修更困难和耗时。
Son Düşünceler
Onarılabilirlik Puanı
(10 en kolay onarılabileni)
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
7 Yorum
About the fingerprint sensor: It should say SYNAPTICS S3909 and not Synopsis (EDA tools) and so the statement from other websites that it is free from US components is just wrong. Apart from the fact that the 5G version of the Mate 30 Pro contains even more US parts (TI, Qualcomm, Cirrus Logic)…
I have what seems to be the Hawaii mate 30 Pro but the components on the inside or not as you show the battery is soldered onto the top board which is a board all in itself and the speaker is soldered onto a smaller bottom board which is separate from the top board and is green said of blue and the SIM tray is like twice as long as what shows and on the backing of the phone like the actual backing it has no writing on it whatsoever
