Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
Giriş
无论是在冬天柴火的周围或者在城市喝着咖啡时,您不希望您最喜欢的裤子上出现坏掉的扣子。 在本指南和锤子的帮助下,您可以让您的裤子或牛仔裤几分钟之内焕然一新。
有关更换部件或进一步的帮助,请联系Patagonia客户服务
Neye ihtiyacın var
在孔中插入钉子。
按压钉子使其穿过孔中。
un clou ou une vis? si l'ensemble bouton plus clou ou vis sont verrouillé l'un à l'autre, comment déverrouiller pour disposer du clou d'une part et du bouton de l'autre.
Bonjour Jean Klein ! Je ne suis pas sûr de comprendre. Pourquoi voulez-vous supprimer le bouton du jean ?
If for some reason the button has been put in backwards, you can remove the existing jeans button using a pair of heavy duty wire cutters. A wire cutter that can cut metal up to 1/4". (6.35mm) thick. Be careful not to cut into the waist band.
牛仔裤的前后之间放置一个柔软的面板,像一片木头或者切割垫
确保使用一个小(一磅)的锤子来防止锤子破坏纽扣。
Thought it would be better if I flipped the jeans over and hit the tack instead of the button. But I wrecked it. Don’t do that.
扣上去试一下新的纽扣已经固定牢靠。
Er is een scala aan verschillende typen knopen te koop met de bijbehorende hulpmiddelen.
Deze zijn met een hamer te bedienen, maar ik doe het altijd met de bankschroef , dat geeft me wat meer controle op het proces.
Hieronder een link naar de jeansknopen:
46 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
62%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
10 Yorum
Nice, but let's consider how this situation occurs. The tack comes out of its hole, just simply replacing it is not realistic, unless the new tack is significantly bigger. So how do you "repair" the hole such that it will hold a tack again?
As noted in step 2, you can move the tack over to where the denim isn't damaged. If that will cause the jeans not to fit properly, you can sew a folded piece of denim behind the hole (sew around the edges on the inside of the jeans) and punch the tack through the new piece.
I didn´t have a new button and was in a pinch. Just ripped the old button off completely, jammed it in the tail end of a hammer and yanked it apart with som pliers. Then i followed the instructions in this fix. Worked like a charm, so far...
Thanks I’m gonna try this first!
The best thing to do is patch the hole. I simply use fabric glue and some pieces of blue jeans that you probably have hanging around. Trim off the extra threads and then apply fabric glue to the back of the waist band covering the hole made by the old button. Do the same on the front and then let dry. about 30 minutes or so, if you have a machine I always stitch back and for on the edges. Trim any edges or use additional glue to tack them down. Now because you have strengthened the hole carefully push the back of the button through where you can see the end, add the front to the nail end and turning the garment face down on a protected hard surface hammer about 3 times and check to see if it is sturdy, continue to hammer until you have reached the objective. Now you have got many more years with that button.
The tack was damaged while we were trying to repair it for ourselves. Says here no new tacks available. Are we at the end of the repairable road??
