Ana içeriğe geç
PlayStation 4 Power Supply Replacement
Neye ihtiyacın var
  1. PlayStation 4 Power Supply Replacement, Flip over the PS4: adım 1, 1 resimden 1.
    • Flip the PS4 upside-down with the back side facing towards you.
  2. PlayStation 4 Power Supply Replacement, Remove the warranty stickers: adım 2, 3 resimden 1. PlayStation 4 Power Supply Replacement, Remove the warranty stickers: adım 2, 3 resimden 2. PlayStation 4 Power Supply Replacement, Remove the warranty stickers: adım 2, 3 resimden 3.
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. PlayStation 4 Power Supply Replacement, Remove the plastic screw covers: adım 3, 2 resimden 1. PlayStation 4 Power Supply Replacement, Remove the plastic screw covers: adım 3, 2 resimden 2.
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. PlayStation 4 Power Supply Replacement, Remove the rear case screws: adım 4, 2 resimden 1. PlayStation 4 Power Supply Replacement, Remove the rear case screws: adım 4, 2 resimden 2.
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. PlayStation 4 Power Supply Replacement, Remove the lower case: adım 5, 2 resimden 1. PlayStation 4 Power Supply Replacement, Remove the lower case: adım 5, 2 resimden 2.
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. PlayStation 4 Power Supply Replacement: adım 6, 2 resimden 1. PlayStation 4 Power Supply Replacement: adım 6, 2 resimden 2.
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  7. PlayStation 4 Power Supply Replacement, Remove the power supply unit: adım 7, 2 resimden 1. PlayStation 4 Power Supply Replacement, Remove the power supply unit: adım 7, 2 resimden 2.
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  8. PlayStation 4 Power Supply Replacement: adım 8, 3 resimden 1. PlayStation 4 Power Supply Replacement: adım 8, 3 resimden 2. PlayStation 4 Power Supply Replacement: adım 8, 3 resimden 3.
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
Sonuç
190 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
72.472 İtibar
288 adet Kılavuz yazıldı
69 Yorum
Gonna do this tomorrow, I'm just hoping this is what's wrong with it.
A few months ago something popped in the system and I smelt a burning scent.
Diamond - Yanıt
Bro,did it work for you?
I have same problem
EL cablemo -
I have same thing.
Erik Ferguson -
Just be careful when pulling up power supply on the left side facing you when Ps4 is upside-down.
jerrylaird3000 - Yanıt
Oui c’est exactement ça j’ai arraché un câble.
Est-ce que quand je vais commander le bloc d’alimentation j’aurais j’aurai un autre ?
Fazel Slh -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 42
Son 7 gün: 410
Son 30 gün: 1,900
Her zaman: 331,106
