Giriş
如果你的主板(或者其他板,HDMI, USB,等等)出现故障并且需要更换它,本指南可以帮到你。注意任何自行更换配件和拆解都会使索尼的质保失效。
卸下主板需要分离处理器及散热片之间原厂的散热胶。在你重新组装你的设备时,需要重新涂抹一层新的散热胶。参考本指南以了解更多。
Aletler
Parçalar
向下按压金属释放条,并小心地拉出扁平线缆以从光驱上断开扁平线缆的连接。这不需要用很大力。
从主板上断开线缆另一端;请确认向下按压了金属释放条,并小心地拉出扁平线缆。
参照下列步骤的相反顺序重新安装你的设备。
157 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
11%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
34 Yorum
Regarding the three wire plug in step 20 - is there a good way to repair this piece if, say, you pulled the wires out of the connector by accident? is there a place to get a replacement part?
I have tried to replace the hdmi port however being somewhat of an idiot I slipped and knocked off onto the little black squares just behind the port on the left hand side. Does anyone know what these are?
contacts of the motherboard
You may be talking about capacitors that are critically important for the unit to function.
South30 -
