Giriş
如果你的主板(或者其他板,HDMI, USB,等等)出现故障并且需要更换它,本指南可以帮到你。注意任何自行更换配件和拆解都会使索尼的质保失效。
卸下主板需要分离处理器及散热片之间原厂的散热胶。在你重新组装你的设备时,需要重新涂抹一层新的散热胶。参考本指南以了解更多。
Aletler
Parçalar
向下按压金属释放条,并小心地拉出扁平线缆以从光驱上断开扁平线缆的连接。这不需要用很大力。
从主板上断开线缆另一端;请确认向下按压了金属释放条,并小心地拉出扁平线缆。
参照下列步骤的相反顺序重新安装你的设备。
157 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
11%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
34 Yorum
Regarding the three wire plug in step 20 - is there a good way to repair this piece if, say, you pulled the wires out of the connector by accident? is there a place to get a replacement part?
I have tried to replace the hdmi port however being somewhat of an idiot I slipped and knocked off onto the little black squares just behind the port on the left hand side. Does anyone know what these are?
contacts of the motherboard
You may be talking about capacitors that are critically important for the unit to function.
South30 -
You mean that little brown parts next to the desoldered HDMI port chip? Seems to be capaciators.
Check it with a multimeter: No connection through that parts: Capaciator, Connection through that parts: Coil
Ok so I was taking mine apart, and while I was separating the ribbon wire from the optical drive during step 7, I broke the top off the connector by accident. I thought I could fix it with hot glue, but my ps4 doesn't read disks (at all, doesn't even know there's a disk in the drive). Is there a way to repair this without getting a new drive?
when I bought the replacement motherboard and optical drive and installed everything, I got a message saying connect USB with software update. Is this because I'm using my original hdd from my original mobo+ optical drive that is different from the hdd my replacement parts came with?
Could you please tell me where you bought a replacement motherboard from as i've been looking everywhere!?
Does your blu-ray drive still work on the new motherboard? I seem to recall on the PS3 that the blu-ray drive was tied to a console, I assume you had to reformat the HDD also?
Cómo saber que tarjeta es la indicada
Es q tengo una ps4 slim y la tarjeta está dañada pero nose cual es la indicada xq trae unos números y nose si afecta en algo
Por favor la respuesta a mi correo gracias :: oscardanilo1724@gmail.com
Desarme la ps4 la limpie arme y andaba…resultado que cuando saque la fuente de alimentación desconecte un pin que que está en la placa base es blanco con unas fichas lo solde e igual no funciona …le pasa corriente pero muy poca que puede ser ayudaaaa
Pablolopez1095@gmail.com ayuda …es mi correo alguna
Brought a used ps4 any idea how to remove the ribbon port of the motherboad step by step to replace. Someone put crazy glue on it..
Thanks for this informative post <a href="http://www.buyplaystation.com/">buyplaystation.com</a>
I ordered a new HDMI port because it was just a black screen but the receivers on the motherboard are worn down, what should I do
thanks for the post myhelmetsguide
Hi Iwas cleaning my ps4 and pull the power connection and it is lose I bought another ps4 and tried to put my hard drive in the new one but doesn’t work. Somebody can help me. It’s posible just to change the mother board I have a lot of games there. Thanks
Motherboad of ps5 we are wating for the ps4 we need best hard drive for ps4 which can enhance the capability of ps4.
Welding gla a
welding jkgfkjjfhkfiyfyiryiriyriyriyr
tig hjjjjjjjjjjjjjjjjjjjjfkkkkkkhhkfkfkhf
sir i want ps4 motherboard,did u have ps4 motherboard.
I’ve read along the guides that a BDP-020 optical drive can work with an SAA-001 motherboard, but mine still receives the CE-35888-2 error. Am I replacing the incorrect part?
Hi my ps4 has stopped working and doesnt turn on at all, ive tried different outlets and different power cables for the ps4, still no luck. Ive pulled it apart and had a look at the power supply board and mother board aswell as dusted it all out. The mother board has yellow stains/ dots near the hdmi port and some other random spots around the mother board. I have the first ps4.
Does anyone know whats wrong? Id rather fix it than pay for a new one.
