Ana içeriğe geç
Removing factory feet from a Mac Laptop (Non-Retina)
Neye ihtiyacın var
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: adım 1, 2 resimden 1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: adım 1, 2 resimden 2.
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: adım 2, 3 resimden 1. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: adım 2, 3 resimden 2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: adım 2, 3 resimden 3.
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: adım 3, 3 resimden 1. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: adım 3, 3 resimden 2. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Opening Picks (Set of 6)
    Satın Al
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: adım 4, 2 resimden 1. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: adım 4, 2 resimden 2.
    Adhesive Cleanup Kit (Set of 12)
    Satın Al
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Nick
88.752 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.521 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 58
Her zaman: 4,346
