Ana içeriğe geç
01 | XY Frame Assembly
Neye ihtiyacın var
  1. 01 | XY Frame Assembly, 01 | XY Frame Assembly: adım 1, 3 resimden 1. 01 | XY Frame Assembly, 01 | XY Frame Assembly: adım 1, 3 resimden 2. 01 | XY Frame Assembly, 01 | XY Frame Assembly: adım 1, 3 resimden 3.
    • M8 x 40 screw for each corner. Insert T Nuts before M8 screws and do not tighten them now. Just to keep the frame in shape.
    • Blind L metal brackets for Z axis assembly should be inserted before M8 screws as well.
    • There are M8 holes for Z axis assembly on the 320mm aluminium extrusions which should be at the back of the XY Frame. Larger hole should be faced to bottom.
    • Insert two T-nuts for every corner in order to fasten the L brackets on the next step.
    • Do not forget to insert T Nuts for Y motor holder in back and LCD mount in front.
    FixBot'a Sor
    Yorum Ekle
  2. 01 | XY Frame Assembly: adım 2, 3 resimden 1. 01 | XY Frame Assembly: adım 2, 3 resimden 2. 01 | XY Frame Assembly: adım 2, 3 resimden 3.
    • One Metal L Brackets for each corner.
    • Two M6x12 socket cap screws for each metal L brackets.
    • Please align the extrusions on a flat surface like glass or marble and then tighten the M8 screws on the corners and the inside L brackets.
    • T-Nut insert for each bottom corner.
    • Printed Zaribo L brackets.
    • Misumi rubber foot for each corner.
    • M6x20 socket cap screw.
    • Misumi 3030 aluminium extrusion edge cover.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Murathan Araz
780 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 46
Her zaman: 3,374
