Ana içeriğe geç
100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Videoya Genel Bakış
  1. 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above, Why the important battery message appears: adım 1, 1 resimden 1.
    • Why the message appears after battery replacement?
    • Chips used in batteries of iPhone XS and above feature an authentication module which stores information that can be used to pair the battery cell with the phone’s logic board.
    • To remove the Important Battery Message, we can transplant the battery management system of the original battery to the replacement battery.
  2. 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above, Remove Original BMS: adım 2, 1 resimden 1.
    • Here we will use a new iPhone XS battery cell.
    • Tear off the insulation tape on the original battery management system. Then remove the protective cover. Remove the battery management system with Cutting Nipper afterwards.
    • Be careful during your operation. Do not tear the battery flex cable or damage the battery management system.
  3. 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above, Weld Original BMS: adım 3, 1 resimden 1.
    • Now we need to weld the original BMS onto the new battery cell.
    • Cut off a part of the nickel sheet on the new battery cell. Then place the BMS in the right position. Do not confuse the anode with the cathode.
    • Continue to weld the BMS with the welding machine. Once done, apply the protective cover and insulation tape.
  4. 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above, Test: adım 4, 1 resimden 1.
    • Activate the battery with the activation board. Then get the battery installed.
    • Connect the screen and then the battery. Power on and test. There is no important battery message this time.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Phryne
20.329 İtibar
18 adet Kılavuz yazıldı
14 Yorum
Thanks for sharing! What device can be used for welding the parts? I don’t want to damage the cells of the battery in this proces?
Also will the new battery will be displayed as 100% in the settings menu?
halders - Yanıt
You need a welding machine as shown in the video to finish the job. And you will get the same battery health as before.
HAKU_LYU -
No need for a welding machine according to this youtube vid (see around 2 mins in). Just a cheap soldering iron can be used.
ieffedit -
Now you gave ideas to apple to make the BMS module like the one from laptops: once you disconnected the cell it will require re-programming (which is not possible because of a security key) :)
Florin Neagu - Yanıt
Instead of welding, would silver conductive glue work to attach the BMS to the new battery?
duff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 12
Her zaman: 41,570
